![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-8.jpg?v=1632732196&width=563)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-7.jpg?v=1632732486&width=565)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-1.jpg?v=1632732486&width=564)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-6.jpg?v=1632732486&width=565)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-5.jpg?v=1632732486&width=565)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-4.jpg?v=1632732486&width=566)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-3.jpg?v=1632732486&width=564)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6300PRO-2.jpg?v=1632732486&width=563)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/3-1_a9c41571-54bf-4f19-ae6b-6d630a242497.jpg?v=1632732435&width=1200)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/311_443b8925-a188-4bb5-ac40-271a94646365.jpg?v=1632732435&width=1200)
![Blackview BV6300 Pro Rugged Phone Ultrasottile [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/3114_a08c9003-be6c-4863-b130-4fbb9f6181cd.jpg?v=1632732435&width=1200)
BV6300 Pro
Più leggero, più sottile che mai
- Corpo sottile da 11,6 mm
- Batteria a lunga durata 4380 mAh
- Fotocamera posteriore Samsung® 16MP Quad
- MediaTek Helio P70, 6 GB + 128 GB
IP68 e IP69K e MIL-STD-810G
Temperatura di operatività -30 ℃ ~ 60 ℃
11.6mm
Plus dur, plus mince, plus léger
4380mAh Batterie longue durée
Charge sans fil 10W | câblée 18W
Caméra arrière Samsung® 16MP Quad
120° champs de vision & HDR
MediaTek Helio P70, 6GB+128GB
6GB RAM 128GB ROM
Android 10
Bandes mondiales et double VoLTE 4G
Gris
Vert
Jaune
Più duro, più sottile, più leggero Goditi la differenza
Per offrire una qualità super robusta e duratura, prestazioni fluide e affidabili, mentre rendendolo più portatile e maneggevole, questa è la differenza che stiamo implementando nel BV6300 Pro. Ideale per lavoro e gioco. Più ampio nelle occasioni d'uso.
Ultra Rugged è il suo DNA Una certezza grazie alla certificazione militare
Progettato con precisione sofisticata, questo dispositivo Military Standard 810G è sempre pronto per all'uso negli ambienti più difficili ed estremi. Sul posto di lavoro, sul campo o quandi sei in cerca di avventura, ti consente una tranquillità senza pari.
- IP68 e IP69K e MIL-STD-810G
- Impermeabile fino a 1,5 m di profondità per 30 minuti
- A prova di caduta fino a 1,5 m di altezza
- Completamente a prova di polvere
- Temperatura di operatività -30 ℃ ~ 60 ℃
Ottieni risultati da fotografo professionale senza bisogno di sforzo
Non solo BV6300 Pro può sopravvivere alle tue impegnative attività quotidiane, ma può anche immortalarle con foto straordinarie. Grazie al set di telecamere quadruple posteriori: fotocamera principale Samsung® da 16 MP, fotocamera grandangolare 120 ° Sony®, fotocamera macro, fotocamera di assistenz. È possibile catturare la realtà metre la stai vivendo, modificare e condividere facilmente i risultati immediatamente.
Foto fantastiche, di giorno o di notte
Con la modalità notturna intelligente, il BV6300 Pro produce senza sforzo foto nitide a bassa leggero. E tutto avviene automaticamente. Che tu stia partecipando a un concerto a tarda notte o trascorrere un crepuscolo in spiaggia, il BV6300 Pro è all'altezza del compito di catturare i momenti.
Ottieni quell’effetto surreale dii timewarp che ami - con la modalità slow motion - rallenta tutto.
Efficiente sempre e comunque
BV6300 Pro incorpora il processore octa-core MediaTek Helio P70: leader del settore per un funzionamento rapido e affidabile. Con 6 GB di RAM e 128 GB di spazio di archiviazione, BV6300 Pro si distingue per il multitasking e la modifica di file di grandi dimensioni, è in grado di salvare fino a fino a 26000 brani.
Più ore pe rdivertirsi, meno tempi morti.
Con una batteria a lunga durata da 4380 mAh, puoi utilizzare BV6300 Pro quanto vuoi senza dover vivere con l'ansia da batteria scarica. Ottimo per uso esterno e adatto al trasferimento di batteria per i tuoi amici o compagni d’avventura che rimangono a secco grazie alla funzione OTG.
Visualizzazione In-Cell display migliorata
BV6300 Pro utilizza un display sottile e vibrante incorporato. Fornisce immagini, video e testi più nitidi e vivifi, nonché un'esperienza visiva più piacevole.
Funzionalità ancora più incredibili
NFC
La funzione NFC intuitiva ti consente di utilizzare Google Pay, acquistare biglietti per i mezzi pubblici e condividere file con altri smartphone.
Sblocco ad impronte digitali
Sensore di impronte digitali montato sul retro e quindi facilmente raggiungibile. Sblocca in un batter d’occhio. Non è necessario inserire la password o disegnare strane figure geometriche.
NFC
Bande globali e Dual 4G VoLTE Connessioni molto più veloci
BV6300 Pro supporta 32 bande globali, rendendolo la scelta ideale per i tuoi viaggi in tutto il mondo. Dual 4G VoLTE offre elevate prestazioni di throughput di dati, una copertura più affidabile, un consumo di energia inferiore e una qualità costante delle chiamate in HD con connessione dati.
Android 10 Esplora un mucchio di nuove funzionalità
Più intelligente, più sicuro, più facile da usare. Scopri un insieme di funzionalità Android al passo coi tempi nel BV6300 Pro, come la navigazione gestuale e il tema dark.
