![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/20377dbf67db38f3c351fc339bf0183f_2c5e92bf-19a9-4733-b88a-b631537ced47.jpg?v=1632731419&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-5.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-4.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-1.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-3.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-7.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/BV6600-6.jpg?v=1632731422&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_green.jpg?v=1673588971&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_green-1.jpg?v=1673588972&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_green-2.jpg?v=1673588972&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_green-3.jpg?v=1673588972&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_green-5.jpg?v=1673588972&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_orange.jpg?v=1673589078&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_orange-1.jpg?v=1673589078&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_orange-2.jpg?v=1673589078&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_orange-3.jpg?v=1673589079&width=1200)
![Blackview BV6600 Rugged con Grande Batteria [Blackview Italia Ufficiale ]](http://cdn.shopify.com/s/files/1/0548/6647/7278/products/bv6600_orange-4.jpg?v=1673589078&width=1200)
Alimentato da un’incredibile batteria da 8580 mAh
Una batteria folle - da 8580 mAh con ricarica inversa supportata. Massima resistenza all'acqua, resistenza alle cadute migliore rispetto a qualsiasi telefono dalla batteria di grandi dimensioni. Le riprese subacquee diventano la norma con la modalità fotocamera subacquea. Blackview BV6600 ha tutto: ti offre un'esperienza di telefonia mobile senza precedenti.
Batteria Mostruosa da 8580 mAh
Capacità superiore del 53% rispetto alla media
Tempo in standby con rete dati fino a 792 ore e tempo di standby con 4G / WiFi fino a 430 ore. Non soffrirai mai più l’ansia da batteria.
Tecnologia avanzata a doppio nucleo elettrico
Più sicuro e più stabile. Offre la migliore esperienza possibile, 8580 mAh senza compromessi.
Più resistente di qualsiasi telefono con batteria dalle grandi dimensioni Certificazione IP68 e IP69K e MIL-STD-810G
Trattandosi di un telefono robusto serio, BV6600 ha un'eccezionale resistenza all'acqua, alle cadute, agli urti e agli abusi quotidiani che non possono essere eguagliati da un dispositivo tradizionale in una custodia semplice.
Una struttura solida per un'eccezionale resistenza a cadute e urti
Cadre métallique fixé par des vis
Angolo in gomma ispessita per una grande protezione
Unibody resistente per ridurre il rischio di rottura
Batterie doppie, ben fissate, per una maggiore stabilità e sicurezza
* BV6600 è resistente alle cadute fino a 1,2 m - test di laboratorio
Tecnologia impermeabile leader del settore
BV6600 è appositamente progettato per soddisfare alti standard, anche in ambienti umidi, con parti interne protette da membrane impermeabili, nonché un tappo di carica anti-deformazione.
- * BV6600 può essere immerso fino a 1,5 metri di acqua dolce per un massimo di 30 minuti
- * Si consiglia di asciugare all'aria BV6600 dopo l'immersione in acqua
Telefono robusto e power bank: tutto in uno con BV6600
Supportando la funzione di ricarica inversa, BV6600 può fungere da enorme batteria con capacità di 8580 mAh per prestare la sua carica a un altro dispositivo. La porta di ricarica di tipo C semplifica il collegamento.
Scatta foto epiche sia a terra che in acqua
Le modalità Subacquea e PortraitColor sono disponibili sia per la fotocamera posteriore che per quella anteriore. Sono disponibili anche le modalità Ritratto e Bellezza, che ti consentono di scattare come un fotografo professionista.
Fotocamera posteriore Samsung® S5K3P9SX da 16 MP
Fotocamera frontale Sony® IMX219 da 8 MP
Sotto l’acqua
Avvicinati il più possibile ai soggetti per mantenere nitidezza e colore.
RitrattoColore
È facile ottenere un ritratto in stile studio evidenziando l'oggetto su uno sfondo grigio.
Buon equilibrio tra robustezza ed estetica sullo schermo
Il display HD + da 5,7 pollici utilizza la tecnologia in-cell per assicurare colori vividi e naturali in ogni fotogramma. Protetto dal Corning Gorilla Glass, ha una grande resistenza a crepe e graffi. Difficilmente avrai a che fare con incidenti assieme BV6600.
5.7
pouces
1440 x 720
Risoluzione
18:9
Proporzioni
Esperienza fluida e risposte rapide alle tue richieste
BV6600 è dotato di una veloce CPU octa-core per un'esperienza fluida. Accoppiato con 4 GB di RAM, 64 GB di spazio di archiviazione con espansione della scheda microSD da 128 GB, senza preoccupazioni per salvare fino a 150 film.
MediaTek Helio A25, octa-core
4 GB di RAM 64 GB di ROM
Espansione da 128 GB
GPS, GLONASS, Beidou e Galileo
Più sono e meglio è quando si tratta di satelliti. Il sistema di navigazione quadruplo di BV6600 consente una correzione dell'ambiguità più rapida e affidabile anche in montagna e in luoghi sperduti.
Sistema operativo Android 10
Naturale come il respiro
Il sistema operativo Android 10 è intelligente, rapido ed efficiente con funzionalità user-friendly: interfaccia utente minimalista, iconografia squisita, gesti di navigazione intuitivi, modalità oscura a risparmio energetico, scala di grigi antimicchia, cassetto applicazioni e molto altro.
Anche le piccole cose contano
![]() NFC multifunzione L'intuitiva funzione NFC consente di utilizzare Google Pay, acquistare biglietti per i trasporti pubblici e condividere file con altri smartphone. |
![]() Sblocco delle impronte digitali Sensore di impronte digitali montato lateralmente, facile da raggiungere. Sblocca in un batter d'occhio. Non è necessario inserire password o sequenze strane. |
![]() Dual 4G VoLTE BV6600 supporta 4G VoLTE in entrambi gli slot contemporaneamente, godendo di una trasmissione dati più rapida, un consumo energetico inferiore e una connessione più affidabile. |
Telefono senza paura che supera i limiti di utilizzo
Tranquillità ogni volta che esci
Scattare foto sott'acqua
Attività ininterrotte, indipendentemente dalle intemperie
Raccoglilo per usarlo dopo una forte caduta su terreno accidentato
Trasporta il tuo BV6600
Con le dimensioni perfette
Verde
Nero
Arancione
